coolmom42
Feb 06, 2016Explorer II
IdaD wrote:
Use 1/4 cup bleach to every 15 gallons, fill the tank with clean water (and the bleach), and then run each faucet until you smell bleach. Let a sit a few hours and flush it a couple of times, and you should be good to go.
This.
It may be the tank, but it could also be your water lines or HW heater. Just clean the whole system, it's pretty easy. DON'T go overboard with the bleach, the ratio above is fine. Otherwise you will have a hard time getting rid of the smell/taste. If you do this at least once a year you should never have a problem. It also makes the tank water perfectly safe to drink & cook with, no need to carry so much bottled water.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
