Coach-man
Feb 07, 2016Explorer
Old-Biscuit wrote:
Tank heaters should turn off at 66*F (on at 44*F)
Bacteria can grow in water temps above freezes but usually need temps above 70*F
Has your cold water been 'warm'?
Where was last place you filed tank....that water could be just different enough to upset dogs.
Have you tasted the water?
I only mentioned the tank heaters because that is what is different on this trip. Before getting here, I filled the fresh water tank in Hearshy, there policy in winter was no hose connected overnight, they stated fill your fresh water tank, then disconnect, which is what we did. And no, even with the "plug in hose", the cold water remains cold.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
