- laknoxNomad
JesLookin wrote:
We used to have the same problem with previous campers we've had. On our current Arctic Fox there is a 2" drain for the fresh water tank. It has a similar valve to gray and black tank drain valves.
My old Komfort had the same thing. About 3 minutes from full (45 gal) to dribble, then another 10-15 dripping.
Lyle - 3oaksExplorer
Gearitis wrote:
Depending upon the state. In some states it is illegal to dump anything on public roadways, INCLUDING FRESH WATER.Blazing Zippers wrote:
I found that if I open a faucet, it flows quicker.
Depending on the situation, I open the fresh water tank, all faucets, and the hot water heater when I'm heading home--yeah, I'm a law breaker. However, when we get to the homestead, most of the water has been shaken out and winterizing is simple.
Law Breaker??? - 3oaksExplorer
JesLookin wrote:
Yep, our A.F. has an 1-1/2" drain valve on our fresh water tank. I have to get out of the way fast when I pull it open. :B
Huge difference from the ridiculous little 3/8" petcock valve to drain the fresh water tank on our previous TT. - JesLookinExplorerWe used to have the same problem with previous campers we've had. On our current Arctic Fox there is a 2" drain for the fresh water tank. It has a similar valve to gray and black tank drain valves.
- CabinetmakerIIExplorer
ksg5000 wrote:
30+ gallons takes a long time to exit small drain tube - I open the valve and grab a beverage - not much different than most
I like your style! I have 100 gallons to drain out. Usually a 3 beverage job. But after 3, I care a lot less ;);) - lee_worsdellExplorerI have the same issue 94 gallons and a 1/2 line. takes at least 3hrs from full
- GearitisExplorer
Law Breaker??? - ksg5000Explorer II30+ gallons takes a long time to exit small drain tube - I open the valve and grab a beverage - not much different than most
- Blazing_ZippersExplorer III found that if I open a faucet, it flows quicker.
Depending on the situation, I open the fresh water tank, all faucets, and the hot water heater when I'm heading home--yeah, I'm a law breaker. However, when we get to the homestead, most of the water has been shaken out and winterizing is simple. - Itinerant1ExplorerIf you have an outside shower area connect a garden hose and turn the pump on 2-3 gallon a minute drain.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 04, 2026
