slomark
Mar 03, 2015Explorer
Fresh Water Tank Fittings
I'm in the process of installing a second fresh water tank, when I also purchased the fittings with the tank. Unfortunately there weren't any instructions for the installation of the fittings, and RV Parts Nation has provided no assistance.
It seems that the proper size hole is drilled and the black rubber portion is inserted into the hole, and then when the fitting is screwed into it, the rubber expands and supposedly makes a water tight seal.
Before I drill into the water tank, I'm wondering if anyone has had any experience with these fittings?
