94-D2's avatar
94-D2
FRESH WATER TANK LEAK
I’ve owned my 2017 Big Horn for three years now. This last August, we had a serious red flag fire warning weekend complete with a PGE Public safety Power shut off. In light of that, I filled my fresh water tank (30-40 gallons) in case we needed to evacuate. Following an all clear, I left the tank full, just in case. In October, I pulled the trailer for a week in South Lake Tahoe CA. Perfect weather and full hook ups. Still had a full fresh tank on board. On day 2 of Tahoe, I noticed a rather large fresh water leak from various points in the undercarriage. I assumed the fresh water was leaking and traveling through the coroplast under the trailer. After three days it stopped. I suspected there was a possible crack in the fresh tank since we had a tire tread incident on the road in February, and a slight showing of water at that time. Upon leaving the resort in Tahoe, I found that the 12v pump didn’t not charge the water system while on tank mode. When I got home, I discovered the fresh rank was in fact empty. I never drained it and concluded it drained o it’s own, and whatever damage was suffered from the tire tread incident was greater than expected.
This last week, I removed the coroplast from the undercarriage of the trailer. What I found disappointed me, but I expected it nonetheless. The bits and pieces of the internal workings of this trailer were haphazardly thrown Together by a kindergartner and as it turns out, caused a water leak in the fresh tank by shoddy workmanship that had nothing to do with the tire tread Was hit on the road.
The fresh tank was installed in its usual fashion. A cross member at one end and three steel straps perpendicular to the cross member. As such, water supply inlet/pump draw tube and low drain hose Were installed and plastic welded next to each other at the bottom of the forward facing side of the tank. Upon filling the tank to capacity for the first time and traveling, caused the tank to bulge on the bottom between the steel straps thereby stressing the welds for the inlet supply fitting that was shoddily welded into place. This caused the weld to fail and produced a leak that drained the tank in three days.
This is the way I found the undercarriage after dropping the coroplast.
