blueglide wrote:
I bought this plastic welder kit a couple years ago and keep it in my rig full time. https://www.polyvance.com/Airless-Welders-1/5700HT/I needed it when I damaged my fresh water tank cresting an unusually steep short slope. It works great and you can also usually find people doing plastic welding/repair in any good size city. The spin weld fittings on your tank can probably be repaired easily since tank is out.
Thank you. I did a torch weld and got about 98%. Still leaked about an inch or two over night. I ordered the weld kit with the iron so should be able to Do it right. I’m not in a big city area so trying myself. Otherwise, Sacramento is just over an hour away. If someone had a shop suggestion for that Sacramento area that would be awesome!
