laknox
May 01, 2013Nomad
YC 1 wrote:
My last rv fill hose was to long and crimped. It was a pain but cutting it to proper length solved the issue.
Do you have two fill options? For example a gravity feed where you hold the hose and the other would be an actual connection to the hose. If gravity filling the tank and the vent is blocked you should get a big burp from it when removing the hose.
x2 on the "burp". Even with my vent working properly, if I fill too fast, I'll get a bath if I pull the hose out before it stabilizes pressure after shutting off the water.
Lyle
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
