I have a '15 Columbus which the fresh water tank was never used. When I winterize with air and drain , I always have a little bit of water come out of fresh water drain. I was going to sanitize my tan...
I wasn't blowing air up the low point drains for hot and cold water. It was the fresh water drain which also looks like a low point drain but is the fresh water drain. I pushed up the drain a coat hanger wire and felt a blockage and after going up and down for awhile it went up and drained the tank. I filled it and drained it and everything is fine. There must be some debris that blocked it.
