Baja_Man's avatar
Baja_Man
Fresh water tanks....Can they be Black in Color?
My new to me Toyhauler (see sig) has four plastic tanks as follows:
1 - Black tank (40gal)
1 - Gray tank (35 gal)
2 - Fresh water tanks that are connected by a flexible piece of hose. These tanks are supposed to be 60 gals each.
NOTE: ALL tanks above are black in color (black plastic).
Question:
Aren't fresh water tanks supposed to be white/milky white/white translucent in color? Never paid much attention to the color of my other RVs fresh water tanks.
Thanks
  • mine were black ABS, made a repair. Don't know the new ones, all covered up.
  • Pretty common to have black tanks. You dont really want light in your tank as that promotes growth of bad things.
    I have yet to see a toyhauler with 100+gal of fresh water that has black/grey tanks that will hold ALL of it. Not sure why some believe that is the case. My tanks are 150/50/50 gal.
  • I'd be more concerned you have 120 gallons of fresh water on board and only 75 gallons available to store it in black/gray tanks. Something is going to overflow most likely, if you don't keep an eye on things. And of course, tank level sensors never function well or accurately.
  • Yes, some fresh water tanks are black abs, but most are translucent polyethylene.
    Seems odd to have only 35 gal gray tank, with that much fresh water available.
    Jerry
  • Baja Man wrote:
    Question:
    Thanks
    mine have always been white,etc. but if they are made of food grade materials, don't think the color matters. could hide algae build up if black however.
    bumpy
