rockhillmanor
Aug 16, 2017Explorer II
Gray Fox wrote:
Has any one had a Fridge door bottom hinge break, its a NORCOLD Model
# N811. Do you think I can buy just the door?
Had same thing happen. At the time the only answer was buying a door.
Now there are hinges and screws for sale separately.
My short fix while I was on the road was heavy duty lock tite. It kept it together albeit I had to reapply the stuff a couple of times. Then the top hinge started loosening up also.
Prevention is to NOT put anything in the door panel of the fridge the hinges are not made to accommodate any weight in the door.
Thank you Norcold a fridge with door panels for food and you can't use it or chance the door opening and falling off . :R
https://www.amazon.com/Norcold-634166-Door-Hinge-Retrofit/dp/B008KWP6MC
https://www.amazon.com/dp/B008KWM346/ref=psdc_13397451_t1_B008KWP6MC
https://www.amazon.com/dp/B008KWM7VA/ref=psdc_13397451_t2_B008KWM346
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
