Curlida's avatar
Curlida
Fridge making bald spot bigger
Some of you have seen my last post on battery and fridge. Well I finally hooked up temp. House power to Montana and charged the battery full. But still trying to figure a way to shut off fridge, because it's probably going to be 3-4 wks before we can make our first trip( still a lot to learn) and we want to be prepared. Anyway re-read inverter manual and it say turn off switch,which I did and the cooling fan came on and the fridge did not go off. I left it for about ten minutes and fan still runs as does fridge. So more research, I traced the cables to the battery,no problem and then I noticed a power cord from the inverter to an outlet and then wiring going from the outlet to,I'm assuming the fridge. Am I ok just unplugging the inverter from the outlet. Kind of confusing because I would have though to see wiring from inverter to fridge? Sorry to be a pest to all you good people but I'm going hunt around to see if there is an elec. schematic for the Fifth.
