cummins2014's avatar
cummins2014
Fridge Repair
Friend of mine took his fifth wheel in to get the fridge repaired, it was not working on either gas or electric. He thought he was headed for a new fridge. I turned out all it needed they told him was a cleaning. What needs to be cleaned to make a fridge work ??. I have heard where the gas gets clogged up, but will still work on electrical.
  • the burner assembly needs to be taken out and cleaned DO NOT clean orfice with a needle use air. not a hard job ,also the flue chimmey should be cleaned if your not handy? hire a local mobile rv tech ,they come to you and much cheap than a dealer.
  • While cleaning is always a good idea, I think there may be more issue ahead, if it would not work on either mode.
    Jerry
