Sturgeon-Phish
Aug 11, 2014Explorer
Did you have the tow/haul engaged?
I found this to be true on our van after having new tires put on, it actually warped the rotor out of shape and we got the shimmy.
The impacts will have a preset value. What happens is they'll drive a lug nut down then go to the others. The first one driven down gets crazy tight. Re-torquing the lugnut may correct or at least make it better.
After tire work at a tire shop I now losen and retorque the lugnuts.
larry barnhart wrote:
Might be cause by improper torqueing of the lug nuts. Usually it shows up after tire work has been done
About Fifth Wheel Group
