rhagfo
Aug 12, 2014Explorer III
Me Again wrote:rhagfo wrote:
If my Pacbrake worked that poorly, I would demand my money back. I have the advantage of a manual 5 speed, and I also bypassed the ECM, so my Pacbrake is also instant on no delay.
It is also activated by compressed air @ 150psi. I very seldom need to even tap the service brakes on a down hill.
Maybe someday soon I will get a chance to come down the west side of Lookout Pass on I90 in Montana's Bitterroot range!
Russ the point I was trying to make was if I turn off my Banks EB then the Dodge Cummins on compression does little to hold back on hills even with the TC locked(aka grade braking). For some unknown reason the V8 diesels with grade braking do provide a fair level of hold back on hills. Not as good as a EB, but for many years owners like Larry have found it acceptable.
I went down Washington pass eastbound in second gear on the EB without touching my service brakes at 20k+ combined. After the hair pin corner I went up to 3rd and ran that next section and used service brakes once at the corner at the bottom of that section.
Once one tows with an EB, they work never want to not have one. Chris
My bad! Misread your post! Very true, there is some resistance without an EB, but nowhere near enough to feel that you can count on it to slow a load.
About Fifth Wheel Group
