fishingguy303's avatar
Aug 10, 2014
Front-end shimmy comming down the mountain
New to fifth wheel hauling here and experiencing front end shimmy when braking at normal highway speeds (45-60mph) going downhill and hauling. I am hauling a 2013 Dutchman Voltage 3 axle with a 2013 Chevy 3500HD 6.6 Diesel dually and cant figure out what's up? I had the TV brakes checked by the dealer, all is fine, weights are fine. engine brakes are working and the shimmy is still there with a high or a low gain setting, newby here needs help/advise. Thanks, Frank.
  • Community Alumni's avatar
    Community Alumni
    Red-Rover wrote:
    When my front wheel brake rotors overheat I get steering wheel shimmy and yes, the brake mechanics will check out okay after cooling.
    My thoughts also. I have experienced the same symptoms in our mountains.
  • When my front wheel brake rotors overheat I get steering wheel shimmy and yes, the brake mechanics will check out okay after cooling.
  • Thanks Newman, I will check with the dealership on the computer update. mwool, I have a Husky 26 K W hitch and a TrailAir Tri-Glide 21K pin box
  • Do you have a kingpin and hitch designed to eliminate chucking?
  • get updates done on ur computer its not talking well with the trailer hooked up.unplug the trailer and see ifvthe shimmy goes away it will show you what i am saying
