NC_Hauler
Jan 18, 2018Explorer
You may have a High Pressure seal going bad. The cylinder can be removed and seal replaced. The symptoms you describe are those of a HP SEAL deteriorating. You can try some of the things others say, but if the jack continues to collapse some under pressure, or dip down slowly while up... it’s probably HP seal. People who repair cylinders\rams can replace seal if you don’t want to replace the entire cylinder. When front gets really bad. it can cause slides to act up, as well as other rams. I know from experience. Two replaced front rams on LCI 6 ram auto leveling system on my unit.
Jim
Jim
About Fifth Wheel Group
