Ezbagr's avatar
Ezbagr
Front landing gear tip-adjustable foot
I use an adjustable landing gear foot on the landing gear that is closest to the up-down button for the landing gear-no shimming etc.
Pull pin on opposite side lower til adequate-put pin back in-lower
other side til adequate-put pin back in-use down switch to make ground contact with non adjustable side-screw out adjustable side til it makes ground contact and you are good to go. Pretty much always have same pressure on both legs and not twisting fifth wheel frame.
You level trailer side to side before doing this.
