donn0128
Jun 29, 2013Explorer II
Sure. What brand for starters?
Place a hydraulic jack under the frame on that side. Look inside the front compartment. You should see two clamps holding the leg in place. Take the nuts off and tap the bolts out. Pry the clamps apart a bit and lift the leg out. You might have to take the "snaps" hardware off and let the inner part of the leg fall out. But the main part will come out the top. Once on the bench just start taking it apart.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
