austinjenna's avatar
austinjenna
Front landing legs wont work - advice
So my front landing legs wont retract or extend. Here is what I checked so far but still unsure of the issue.
Battery is connected and showing 13.x V
All lights inside/outside etc.. all work fine.
I checked the fuse going to the landing gear switch and its good.
The wires on the extend/retract switch are all connected (its a 6 pin switch). Tracing the positive wire from the battery to the switch, its showing 13.x v at the positive pin on the switch. It has a little jumper on the switch from the positive to another pin - that is also showing 13.x v
I disconnected the wires going to the landing leg motor from the switch and used jumper cables directly to the motor - the motor works.
I then hooked up the positive wire from the landing leg motor going to the switch. For the negative on the motor wire I hooked it directly to the negative side of the battery, pressed the switch and it worked. But only one way which is understandable.
Reattached the neg wire on the motor and nothing happens when using the switch. On the multi meter the positive wire on the motor shows 13.xV when pressing the button on the switch even though it doesn't turn the motor.
I checked the ground wire and it looks good.
So I was thinking it might be the switch itself. What are your guys thoughts?
