opnspaces
Jul 17, 2023Navigator III
If you jumper the positive and negative wires to bypass the switch and the motor works I would replace the switch. One bad thing about a digital meter is it can fool you by showing voltage. But the switch could be so bad that there is no actual current going through.
About Fifth Wheel Group
