resmas
Mar 12, 2012Explorer
jetboater454 wrote:
Never seen one.Main problem would be garage loaded and more 1 day to get where your going to unload the bedroom.
I think the OP means the "master" bedroom would be in the area that the kitchen/dining/living room area is on most TH's. I don't think he meant that the ONLY bedroom would be the garage.
So if you walked from the garage toward the nose, you would pass thru the bedroom, then the kitchen/dining area, and then up in the nose would be the living room. Not quite sure where you would fit the bathroom in there...
If you only needed a 4' deep side-load garage, I guess it could work, but you might end up with a unit that is very, very long.
It would be interesting to see if a manufacturer would be able to build one...
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 23, 2025
