CWSWine's avatar
CWSWine
Front Living Rooms
We are looking the Keystone Montana Front Living Room model 3711FL. It has a DRY pin weight of 2790 lbs at 13200 and CC of 3200lbs. I know for pass scale weights I add under 1500 lbs of cargo. I have F350 diesel SRW with payload of 3744.
If they pin weight percentage stays at or under 22 percent would give me a pin weight of 3234 which still gives me some margin. My question is that seems like a front living room would be lighter pin since there isn't much added weight in to the living room and also not much storage? Also, the basement in the front is the smallest I have seen on any 5er being less 30" wide so not much cargo there.
Does anyone has any input? Upgrading the truck isn't a options since a Crew Cab won't fit in my garage.
