- B_O__PlentyExplorer II
dennych1 wrote:
Try a bigger screwdriver and twist harder.
Just tried screw driver in lock no good. Has anybody drilled one out. If so how big of a drill bit should I use.
B.O. - dennych1ExplorerJust tried screw driver in lock no good. Has anybody drilled one out. If so how big of a drill bit should I use.
- dennych1ExplorerTried lubricating it no good tried banging while turning key no good. I think i will try screw driver if that has worked for others thanks
Dennis - Lenny_KExplorer
B.O. Plenty wrote:
Put a large flat blade screwdriver in the key slot and give it a turn. It will open right up and remind you about how secure it really is..
B.O.
Yes, it is that simple as using a flat tip screwdriver. Been there and done it! - B_O__PlentyExplorer IIPut a large flat blade screwdriver in the key slot and give it a turn. It will open right up and remind you about how secure it really is..
B.O. - DavidPExplorerI would put some silicone or lubricant in the core and see if that frees it up. Slightly push and pull on the key while turning.
Just realized Donn said basically the same thing. - donn0128Explorer IIDrill it out. I just replced two of mine for the exact same issue. They are cheapand easy to replace before youdrill it out, try some lock eze and work the key around a bit. That would eventually get mine to unlock until i got around to replacing them.
- rhagfoExplorer IIIIt could be something in the compartment has fallen on the latch. Try working the key back and forth, also have someone slap the area right above the latch open handed while you try to turn the key, it might just be enough to dislodge the item.
- sdetweilExplorersounds like something might have moved and it resting on the lock..
- Dick_BExplorerIf it works like mine try pushing on the door near the lock and rotate the key back and forth.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
