rockhillmanor
Nov 23, 2018Explorer II
padredw wrote:Kevin wrote:
Water pressure regulator, Surge protector, leveling sensor, charcoal filters, micro leg adjuster, hitch pin tripod and the list goes on.
Kevin, yours is a friendly post and this one is intended to be. I've been traveling in a fifth wheel for over 20 year (four different rigs). I would look at it this way, you have gained some good information:
Most important, you've saved yourself some money and a lot of trouble by knowing that the hitch pin tripod does not seem to help most of us and the one we have is stored away in the garage.
And the water pressure regulator is better at the city water hookup, not on the RV.
Same for the surge protector because some of us want the portable model rather than the built in model.
That leaves only the leveling sensor and the micro leg adjuster which many I must admit I don't recognize.
I would venture to say thatwith experience you will find the items you have mentioned are probably better considered optional with each owner.
Just my thoughts.
X10
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
