Gearitis
Jun 25, 2015Explorer
You may have a coaxial splitter in the mix. The Satellite connection will not work well or not at all if the signal is split in anyway or the splitter is power passing but not passing a high enough frequency. Satellite reception is up to 2 ghz so a 900 mhz splitter is not high enough frequency. I had that happen on my Sabre. Also, another thing is that a lot if not most are not cabled and properly marked. Several people have found that something labeled satellite was cable and some labeled Offair Antenna was satellite. You may need to trace cables to see where they actually lead.
About Fifth Wheel Group
