RUIDOSOSHAW's avatar
RUIDOSOSHAW
fuel gauge not working
fuel gauge not working in weekend warrior FS2300 toy hauler and can not figure out the wiring. It does have a radio that also does not work, so there is a lot of wires back there. Can anyone help me out. Thanks for your time and help.
  • I don't have an answer but this would get more exposure in the Toy Hauler section or the Tech section. This is not a General RVing subject.
    Maybe a moderator will move it for you.
  • Yes, it was working fine. The radio never worked, but had a new one installed and it working fine.
  • Had a new radio installed now, but the fuel gauge is still not working. How should the wires be hooked up on switch ( the switch has 4 place to,hook up wires on). Does that mean there should be 4 wire to it. Thanks for any help on this, we live where there is no RV places.
  • In the garage of my toy hauler there is a timer that must be wound up to 15 Min. then outside by the fuel hose there is another switch that must be turned on before the fuel pump and gauge will work
  • Is the battery charged, are any of the lights working, have you checked the fuse pannel and tested all the fuses, pull one by one and check that they are not burnt and replace in the same place.
    If all of the above check, maybe a wire has come loose or a crimp connector has loosened, some radios have fuses on the back, for that you need to remove the radio from the frame, since the rado and the gas gage do not work the gas sender should be OK.
    navegator
