nayther
Jul 02, 2015Explorer
arhayes wrote:
Are you sure is power all the way to the pump itself? I'd still suspect an inline fuse but without knowing if there is power at the pump it's hard to tell.
check power right at the pump and check your ground. If both are good, there's power to the motor and it doesn't at least hum then the motor is bad. To double check try running a dedicated wire from the battery (or other 12v source) directly to the motor.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
