Redwing1
Jul 05, 2015Explorer
Hi AZRocket, electrical is just a mess! Turn your timer on, turn your switch on and check for voltage across the two red wires. If nothing pull the wires off the plug and use your ohm meter to check the switch for continuity, if the switch is good and no power across the two wires go back to the black and red wires in the timer, red should be hot and black ground.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
