AzRocket
Jul 05, 2015Explorer
Redwing1, the last thing I did was this. I turned the dial on (with switch off) and had 12v to the switch. Then when I turn the switch on, the volts were like 0.1 (barely registering). I was grounding the one side of my volt meter and used the red end and put it on both prongs of the switch. Both sides if the switch showed 0.1 (or so). I think I am doing that correctly. I currently have the switch pulled out. I will try to check the ohms on the switch.
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
