billkaufmann's avatar
billkaufmann
Fuel station fuse
I have a 2010 Forest River Shockwave TH. I cannot locate the fuse
for the fuel station. It is not on my breaker/fuse panel or under the rig at the pump. I'm sure there should be one for safety.
Any help will be appreciated.
Bil
  • When I can't find something as simple as an inline fuse, I call the company's tech support team....but then again...the tech says, "let me contact the assembly line" and see what they say, then again, depending on which day your unit was built...that fuse may be "anywhere". Good luck.
  • shawnct450r wrote:
    Should be close to the pump. All of them I have seen are. If not, it's wire-chasing time.
    Bingo...And the cause of the blown fuse has been discussed here. It's either a new paddle kit or re-work the one you have, what I'd do.. IMO..
  • Should be close to the pump. All of them I have seen are. If not, it's wire-chasing time.
  • My fuel station is hooked directly to the battery and has an inline fuse about 8in up.
