Will try powering the motor with out the gears. I have the GPI overhaul kit installed. Did the overhaul when I replaced the motor.
i want to make sure the wiring is correct. The ground from the pump and the ground from the battery are wired together and then wired to load1 on the dial timer. Then the hot wire from the battery is wired to the on/off switch(located next to the dial timer). Then coming from "line1" is a short wire going to the on/off switch.
Any one have any experience with this wiring? I'm not very good with knowing which wire should go where.
