servitrike wrote:
am i correct in understanding that in a solar set up, everythin runs off a DC battery(yeah, like there is an AC battery) thru an inverter. and the goal of the solar array is to supply a DC charge to resupply the batteries at a rate, equal to and well above the recharge rate of the batteries, so as to power the required devices while recharging the batteries?
basically yes. Consider that for high power systems you are better to design around higher voltage such as 24, 48 for increased efficiency and reasonable sized wires.
