bigmichael wrote:
I think there is a bit of confusion on this thread regarding RV consumer groups rating of FT rigs vs manufacturers that don't void the warranty if FTing. The people who are disputing the RV consumer group rating seem to be doing so based on the fact their warranty allows FT use, or the manufacturer claims 4 season use.
If I understand correctly, RVCG does not do their ratings based on the warranty. They do them based on the rig specs. Thus they assign a "weekend" or "vacation" rating to some, a "snowbird" rating to others, and a "full-time" rating to a few. They explain all of the items that go into their rating, things like frame, axels, other chassis components, actual insulation and where, solid wood cabinetry vs vinyl wrap, sidewall structure and build design, use of particle board, residential carpeting and pad etc. etc.
The RVCG material is expensive, so if one doesn't want to purchase it, it can be found in many or most libraries. Its good as another tool.
I do agree with those who say you can FT in anything. We have been FTing 6 years, and have found FTers in many different kind of set ups. There will be differences in comfort and how well things hold up over the years, but people make it work for them.
But I think its at least wise to consider all of your options, and not underestimate the difference FTing can make in wear on your rig. Anyone who thinks there is not a MAJOR difference in wear and tear when you live in a rig 24/7 vs vacationing, weekending, or even snowbirding, is fooling themselves. And as the OP mentioned, they are considering moving a lot. Again, this is significantly different in use than even a FTer who sits still 5 or 6 months in the south in the winter and 5 or 6 months summering in the north.
kakampers wrote:
If that was the case how did the Blackwood make their list?? .
X2
Delightful read - but all nonsense
