RoyB
Feb 06, 2016Explorer II
Again - Have you used the stovetop on this new fillup of propane??? The idea here is to purge air from the propane lines since you have had them disconnected changing out the propane tanks...
The only safety feature I can think of is associated with the blower fan of the furnace. If the furnace fan stops blowing there is a AIR VANE that will shut off the propane fuel that goes to the furnace.
The furnace blower fan is powered by 12VDC which comes from the converter/charger unit when connected to shore power or generator and/or the 12VDC battery... If the ceiling lights are working then this tells you the 12VDC is working and ON.
Roy Ken
Roy Ken
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
