btd35
Jan 29, 2014Explorer
If you are hearing it click to ignite, then it is not the sail switch as the switch locks out the ignition and you will not hear a click. Most likely problem is the ignitor itself, the gas valve coil, or your gas supply has a problem.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
