JamesBr
Jan 29, 2014Explorer
It sounds like an out of propane situation. So check your tanks to make sure you didnt already burn through it all. Check your tanks to make sure both are on (had that happen on my way to FL, filled one tank forgot to turn it on, middle of the night no heat/changeover.)
Check your change over valve, and then if both tanks are full change over is happy, cycle the furnace and see if you hear flow in the regulator...it can freeze up as mentioned.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
