pinesman wrote:
This is what I do if towing below 35F. But only if safe and convenient.
Thanks everyone. I think I will probably stop about 30 minutes before my destination Friday and start the furnace to knock off the chill before I get there.
My slide only covers one vent 50% and even then I might wedge something under the flap of carpet so it can breathe. Other four vents are always clear.- brialinExplorerWhen my slides are in two out of three vents are almost completely blocked off by the slides. I will not turn on the heat unless all the vents are open 100%.
- 94-D2ExplorerWhat about running the furnace with the slides in. I ask because if I am stored at home in the winter, I would rather have the slides in if freezing rain or snow, and keep the water lines from freezing. It only usually freezes at night here where I live.
TxGearhead wrote:
ford truck guy wrote:
For OUR RV, we don't need to do that, it will heat up very fast.. Usually by the time I am done setting things up and scanning the TV, we are getting warmer....
We just turn on the LP heat AND the electric fireplace..all is good !
What are the odds you're at the sprint car national finals in Charlotte?
They got qualifying in before the rain!
Nope, the Redwood was dropped at the dealer yesterday for a small list of warranty items to complete. Been making a list since we got it in May..
The last thing being done is the pink stuff will be added :(- pinesmanExplorerActually it is the Va Tech game
- TxGearheadExplorer II
They got qualifying in before the rain! - For OUR RV, we don't need to do that, it will heat up very fast.. Usually by the time I am done setting things up and scanning the TV, we are getting warmer....
We just turn on the LP heat AND the electric fireplace..all is good ! - Old-BiscuitExplorer IIIWE have done it on several occasions while traveling in COLD temps.
Enclosed underbelly stayed warm...water lines stayed warm & inside of 5vr was warm while setting up.
No harm/no foul---all good!
Hot summer time...we run A/C Unit while traveling - Jayco-noslideExplorerI don't think I have. I did fire it up once at a rest stop when it was very cold. Seems safer not to but not sure why except to avoid pulling up close while refueling. We do always leave our frig on running on propane so guess that would be the same risk.
- Community AlumniNot applicableI don't see an advantage to running our furnace in route as the living area vents are covered by the slides. This could effect the furnace due to limited air flow. We start the furnace as soon as the slides are out and if it is very cold I run an electric heater to get the temperature up quickly.
About Fifth Wheel Group
