debraindi wrote:
I seldom cool or heat the garage and know little about heat pumps. I close all the vents in the garage for the Ac directing air to the living area. It worked fine for the living are in 100 degree it will take some time to cool with 2 Ac. when I'm connected to 50 amps there is no problem cooling my 311 Impact fusion. You could long into http://www.keystonerv.org/forums/index.php
Heat pump is multi purpose...You can use it for heat or as an AC (similar to a heat pump used on home sites, just looks like a AC on TH roof)) ...if temps fall below freezing, use the furnace..If warmer you can use the heat pump...Had two carrier heat pumps on my last 5er and it really worked out well. If it gets warm to hot, you have 3 AC's, if you need that many.
