720Deere
Sep 08, 2013Explorer
glazier wrote:
I am up in the air now about what I will buy.
A new storage barn is what you need! LOL
No complaints so far with our 2013 Fuzion 315. I picked it up the first weekend in October last year and have since put a little more than 3,500 miles on it. It is towed with a 2011 F350 equipped with Firestone airbags. There is no doubt that the 315 is on the ragged edge of the ratings of a SRW 350 and definitely over the 250 ratings. That being said, it is withing the axle and tire ratings of the truck and the truck handles it fine.
During our search for a toyhauler, the Fuzion not only best met our needs, but the quality seemed to be slightly better than most of the others. I've had a few small issues that I had taken care of under warranty at the dealer. All of the issues could have easily been corrected here at home at virtually no cost to me, so I'm not complaining.
So to answer your question, yes I think the Fuzions are worth their cost in comparison to other brands. They are all over-priced for what you get, but you gotta pay to play. Whether or not you actually would need a bigger truck, I can't answer that for you because of quite a few variables in your situation that I have no knowledge of. If your tires are rated at more than 3500 psi each and you install airbags, I would think you could make it a year or two with the F250 unless you plan to use the trailer a lot. If it were me, I would probably get the trailer I wanted and make due with the truck I already had for at least a year or maybe two then upgrade the truck. That way you don't get hit with over $100k in expense all at once. If you plan to travel large distances and frequently, I doubt that you will be comfortable with your present truck for very long. Only you can make the decision if you will get enough use/enjoyment out of the trailer to justify all that cost.
About Fifth Wheel Group
