Me_Again
Oct 06, 2015Explorer III
Do you have the jack plate adjustments at all three positions or only at each end? If in all three positions, then it will go up what ever the spacing is on the different hole position. Which is normally 2" between holes. If you are only moving one end of the spring, then it will be about 1/2 the distance.
Which side is the TV steering wheel on???? :h:h:h
Durango is not reversed.
Chris
Chris
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
