Me_Again
Oct 06, 2015Explorer III
alexleblanc wrote:Me Again wrote:
Do you have the jack plate adjustments at all three positions or only at each end? If in all three positions, then it will go up what ever the spacing is on the different hole position. Which is normally 2" between holes. If you are only moving one end of the spring, then it will be about 1/2 the distance. Chris
the Jack plates are only on each end, the center one has two holes and is already in the lower of the two now. So theoretically I can gain and inch of height by making this move then?
Correct!
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
