ZOSO
Oct 06, 2015Explorer
alexleblanc wrote:
Hi Guys,
so I finally went to pick up my new KZ Durango yesterday and the first thing I noticed after I had it hooked up was how nose high it was. So I lowered the pin box to the lowest mounting points, it helped a fair bit but I still feel that 2" difference from front to back is too much. My Hitch is also on the lowest mounting setting. How nose high is too much and how much is acceptable.
how it sits now:
here's my question, my FW has built in adjustment like the one pictured below (mine are on the top holes right now - so the lowest height the FW can be) how much lift do I get going to the middle hole and how much to the bottom hole?
How does it tow? Personally, I don't think 2" difference is a problem, providing it tows alright. Really, the nose is 1" high of level line and the tail is 1" low of level line. Correct??
To me, that's absolutely fine. Nose low would be an issue. If it tows OK, I'd leave it be but it's your rig and your call. ;) Enjoy it!
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
