laknox
Oct 06, 2015Nomad
alexleblanc wrote:
here's a picture I just took over lunch and some numbers - this is with 5PSI in the airbags for now. FW is loaded and more or less camp ready. I may be able to lower the pin box another 1".
Bedside to underside of FW - 8"
Front wheelwell - 39" (38.5" unloaded)
Rear wheelwell - 39.5" (41" unloaded)
Front of FW - 25.75"
Rear of FW - 23.25"
so in total its 2.5" high on the front.
If you haven't yet moved the spring bolts, I'd say you're good to go. Moving the spring bolts will make you a touch more level...if you want to go to the effort to do so. My recommendation still stands, that if you're going to move the spring attachment, install wet bolts all around.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
