alexleblanc
Oct 29, 2015Explorer
Found the tires i'm going to run, it's a Toyo Open Country H/T LT225/75R16E1. It's 1" taller than what I have now so I'll end up with 3" between the tires, that sounds like enough to me. I'll simply get a new set of 16" alloys, many style to choose from.
Specs:
Tread depth - 13.9/32nd
Diameter - 29.3"
Max Load rating - 2680lbs
Max PSI - 80psi
Approved rim with - 6-7"
Tire Weight - 39lbs
Specs:
Diameter - 29.3"
Max PSI - 80psi
Tire Weight - 39lbs
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
