SkiSmuggs
Oct 29, 2015Explorer
alexleblanc wrote:Garry&Gayle wrote:
I would go to the lower hole, then see how level you are. Does your pinbox have any adjustment? The more level you can get it will distribute the axel load between axels better.
I've already adjusted the pin box to the lowest setting, that lowered the front by about two inches.
I am not sure you are saying this right. I RAISED my pin box to the highest position to lower the nose.
Also, put a level on the floor to see if you are truly nose high or does it just look that way. After lowering my pin box and replacing the Dexter EZ-Flex equalizers with MorRyde CRE3000 equalizers to raise the trailer, it still looked a little nose high to me. I put a level on the living room floor and it was perfectly level.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
