alexleblanc
Oct 30, 2015Explorer
SkiSmuggs wrote:alexleblanc wrote:Garry&Gayle wrote:
I would go to the lower hole, then see how level you are. Does your pinbox have any adjustment? The more level you can get it will distribute the axel load between axels better.
I've already adjusted the pin box to the lowest setting, that lowered the front by about two inches.
I am not sure you are saying this right. I RAISED my pin box to the highest position to lower the nose.
Also, put a level on the floor to see if you are truly nose high or does it just look that way. After lowering my pin box and replacing the Dexter EZ-Flex equalizers with MorRyde CRE3000 equalizers to raise the trailer, it still looked a little nose high to me. I put a level on the living room floor and it was perfectly level.
yes, I misspoke what I meant was I adjusted the Pin box up to get the 5er as low as possible up front.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
