- Me_AgainExplorer IIIAnd a single battery will not run it all night. In fact it will most likely drain two group 27 over night! Chris
- RVERExplorerFurnaces in most modern RVs need battery to fire and run fan.
- Atom_AntExplorer
n7bsn wrote:
I had the catalytic type in a tent trailer too and it didn't require any power. Wonder if they still do that.
... and the correct answer is, it depends
I've had two RV heaters that didn't, one was an old-style convection furnace and the other was a catalytic heater.
But the blower type in most RVs require power - n7bsnExplorer... and the correct answer is, it depends
But the blower type in most RVs require power - MarkTwainExplorerThank you for the quick responses to the furnance propane/electricty questions:) Solved the question. Learn something new everyday!
- talonheadExplorerNope, need power to run the furnace and thermostat.
- Mandalay_ParrExplorerThe furnace requires 12volts to run. Both for the fan and control circuits.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
