MookieKat's avatar
MookieKat
Gas mileage comparison between towing TT and 5'er?
We had started out looking at 25' TTs but then went to 5'ers,
A. Because we like to have decent kitchen counter space, especially since we will be living in it for about 6 months while we remodel our house and also another 6 months in CA to see if we really want to move there.
B. We like the higher ceilings (but this may be negotiable)
It seems that in general...the 5er's start at around 30', but the ones with decent counter space have been closer to 35.'
I wonder if this is overkill, for two empty nesters in their early 60s whose primary reason for buying a TT or 5er is to tour around the country to visit the NPs? I am concerned about the gas mileage to tow a 35' 5'er vs a 25'-28' TT. It would take a bigger truck to tow the 5er than the TT, which would most likely give worse gas mileage.
I know...some have said, "If you are towing an RV, don't even think about gas mileage. That is a moot point!" But...we would love to be able to do it as frugally and yet as comfortably as possible. We want to hit the "sweet spot."
So...we are looking at these types to scenarios (Dry weight):
1. 28' TT - 6,000 lbs.
2. 35' 5er - 11,480 lbs.
3. 32' 5er - 8,777 lbs.
Have any of you had experience in this area...where you may have towed both TTs and 5ers to show the difference in gas mileage?
Thanks in advance!
    Thanks in advance!
    Trouble is, it is true....and you will enjoy the adventure a lot more when you accept it.
    Basically, you are going to get between 8 and maybe 12 mpg towing any of the choices you listed while towing around the country to national parks.
    Good luck with your choice.
