beachbum5
Mar 15, 2015Explorer
Gas VS Diesel F250
I am looking at new F250, I have f wheel about 8000lbs. I would like to know gas mileage while towing and not towing, also on diesel. How would gas handle the load?
Thanks
Thanks
Dave H M wrote:diver110 wrote:
I have looked into this issue a lot. Here is the bottom line: If you have the coin, buy diesel. Most likely you will be happier. I would focus more on whether you can afford it comfortably in absolute terms. It is true under some circumstances gas is cheaper. But in some ways that is the wrong question. The right question is in which will you be happier. A Toyota Matrix gets me from A to B, but I'd rather drive a BMW.
Different logic here. I could be driving a diesel in my F250, but chose a 6.2 for my liking. it fits my needs, is what I wanted, and I haven't looked back in 3 years. I think with today's engines it is a lot of whatever blows your skirt up, or as they say turns your crank. you can't convince me that I need a diesel and I cannot convince a diesel owner that he needs a gasser. It will never change.
rhagfo wrote:Allworth wrote:
Torque curve.
The diesel peaks in both horsepower and torque at almost the same RPM (usually around 3K in motor vehicles). Gassers peak torque at about 1800, but the horsepower doesn't build up until much later in the curve.
The total explanation is, of course, much more complex but that is the basics.
I believe you have your numbers backwards.
Most diesel develop max torque at low RPM,this then stays flat and RPMs get the HP at higher RMPs.
Gas gets max torque and HP at higher rpms RPMs to get max torque.
SkiSmuggs wrote:
I much prefer towing with a turbo charged engine. The 8000 (loaded or dry?) pound fiver you mentioned can be towed by an F150 Ecoboost with Max Tow and HD Payload.
I've been doing it for 3 years with a 9500 lb fiver. Now that I am ready for a new truck, it will be an F350 Powerstroke Diesel as the 6.2 gasser would be at high RPMs going uphill vs much lower RPMs for the Ecoboost or a diesel. I am going Super Duty because I am adding batteries and solar to the fiver which adds more weight than I am comfortable with for the F150. And any fiver I get in the future will be heavier than the one I have now with stronger construction and more insulation and features.
Allworth wrote:
Torque curve.
brooks379 wrote:i agree wished i had one
One thing about a F250 with the 6.7 diesel it will handle any condition you can throw at it pulling that trailer. Depending on how fast I drive I get anywhere from 12 to 13 going down the road pulling loaded at 65 70 all day long. The 6.7 has more power than two 7.3's.... it is a monster.
