MFL
Jan 01, 2014Nomad II
2oldman wrote:
The rocker in the WH itself is On/Off electric. The red button is likely the gas on/off.
This is correct. You won't need to use the switch inside to run electric heat. You can run both electric and propane at the same time if you want, to heat water faster.
Never leave the electric switch to on, if you drain the WH. If plugged in, electric on, no water in heater, will burn out heater element.
Jerry
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
